Custom Material to Title block
reutov_tv
Industrial
Jan 16, 2024
33
Hello.
I can't figure out what I need to fix to make the script fill the material field from a user parameter in CatPart (not from PartBody\Material).
Please help.
Thank you.
Piece of code.
Code:
ub CATFormatRBText(textName As String, anchorPosition As String)
  'How to format the texts belonging to the titleblock
  Text.Name           = textName
  Text.AnchorPosition = anchorPosition
  Text.SetFontSize      0, 0, 5.
End Sub
Sub CATLinks()
Dim Material_1  As String
  'How to fill in texts with data of the part/product linked with current sheet
  On Error Resume Next
    Dim ProductDrawn As ProductDocument
    Set ProductDrawn = DrwSheet.Views.Item("Front view").GenerativeBehavior.Document
	err.clear
	Set ProductDrawn = DrwSheet.Views.Item("Вид спереди").GenerativeBehavior.Document
	err.clear
	If Err.Number = 0 Then
    DrwTexts.GetItem("TitleBlock_Text_Number_1").Text = ProductDrawn.PartNumber
    DrwTexts.GetItem("TitleBlock_Text_Number_2").Text = ProductDrawn.PartNumber
    DrwTexts.GetItem("TitleBlock_Text_Title").Text  = ProductDrawn.Nomenclature
    'DrwTexts.GetItem("TitleBlock_Text_Designer_1").Text = ProductDrawn.Revision
    'DrwTexts.GetItem("TitleBlock_Text_DDate_1").Text  = ProductDrawn.Definition
    Dim ProductAnalysis As Analyze
    Set ProductAnalysis = ProductDrawn.Analyze
    DrwTexts.GetItem("TitleBlock_Text_Weight_1").Text = FormatNumber(ProductAnalysis.Mass,3)
    Material_1 = ProductDrawn.Name&"\Material"
	err.clear
	Material_1 = ProductDrawn.Name&"\Материал"
	err.clear
    Set Mat_1 = ProductDrawn.Parameters.Item(Material_1)
    MM1 = Mat_1.ValueAsString
    DrwTexts.GetItem("TitleBlock_Text_Material").Text = Mat_1.ValueAsString
    DrwTexts.GetItem("Text_End_Area").Text  =  intParam1.ValueAsString
  End If
  '    If No Material
    'MsgBox "MM1иииии="+(MM1)
	'MsgBox ProductDrawn.Name&"\Материал" +"      nnnnnnnnnnnnnnnnnnnnnnnnnnnnn"
	'MsgBox ProductDrawn.Parameters.count
	'for i=1 to ProductDrawn.Parameters.count
	'	MsgBox ProductDrawn.Parameters.item(i).name +"     "+ProductDrawn.Parameters.item(i).ValueAsString
	'next
     If  (MM1 <> "")  Then
     Else
         Material_1 = ProductDrawn.Name&"\PartBody\Material"
     End If
     If  (MM1 <> "None")  Then
     Else
     End If
  'InputBoxNameMaterial
   Dim NewText As DrawingTexts
   Dim Variable As String
     If  (MM1 <> "")  Then
     Else
       Set NewText = DrwTexts.GetItem("TitleBlock_Text_Material")
       Variable = InputBox(
