johnhenry1959
- Sep 11, 2003
- 5
When i create drawing with assemblies, sub assemblies and part details, I like to put a descritive note under each particular drawing view eg "Main Drive Sprocket Coupling" Scale 1:5. If i change the scale of the drawing I have to manually change the scale note. I know about the sheet scale option but their are some details which are usually at differnt scales.
Also is their a way (that works) that I can link item numbers of parts (detail drawings) to to the main BOM which may or may not be on the same sheet.
I'm using SW2003
I'm using SW2003
