Custom tapered standoff ??
alan_young_1983
Industrial
Dec 15, 2021
4
Hello everyone,
First post so hopefully I've followed the proper procedure and posting in the right forum.
I'm looking for a component similar to a tapered standoff at least I think that is what is it called. I attached a drawing of the component I'm looking for.
Would appreciate some feedback on what this component is actually called and where I could find a supplier. Trying to avoid going custom.
Thank,
Alan
alan_young_1983 said:
The chamfer is absolutely required. There is a component that slips into the standoff to lock in place.
This requirement pretty much eliminates an off-the-shelf part.
If you don't care about the surface finish of the large OD (ie these could be turned from 5/8" bar) these might cost you a few dollars apiece. CNC lathe is going to crank 400 of those out in a couple of hours at most.
