rockman7892
Is there a standard rule of thumb or guidelines for what maximum MVA load utilities will serve to customers (large utilities, etc..) for given service voltage classes.
For instance:
- For 34.5kV distribution lines is there a typical threshold load that utilities will serve customers from this voltage?
- Same with 138kV, 230kV and other common service voltages?
Common example would be if a customer is being served by 34.5kV and wants to add load that will exceed the utilities max allowance for that voltage class service would they commonly have to discuss with utility an option for getting a higher service voltage provided to the site?
For instance:
