goucho
Aerospace
- Aug 29, 2013
- 10
When you use the Hole command in NX9.0 and dimension it in drafting, a standard text template is used. I was able to modify that by customizing the Hole Callouts in CUSTOMER DEFAULTS->Drafting->General->Drafting Standard. The result can be seen below in the attached picture. However I would like to change the depth callout to 2 decimal places instead of 3 decimal places. I am able to change it by going into settings and modifying the depth drop down, however I want to make this standard so I don't have to change it every time make a hole callout. Any ideas?
I'm aware I can change the standard dimension decimal places under the CUSTOM DEFAULTS->DRAFTING->ANNOTATION section, but this changes ALL dimensions, and not just the depth callout. I'e also search though quite a bit of the NX9.0/UGii folder, but didn't find any files that set these defaults that I could change the coding for.
Appreciate any help!
