Cut condition cutting steel with nitrogen 1
Jonathan Lessard
10
Hi guys I need help when I cut mild steel with nitrogen I get a small drop on corner, I really don’t know on what setting should I play with, my hole are nice and straight head cut are good. Another thing it’s only happen with 14 gauge and 11 gauge
Thank you
picture of my issue and my parameter
hi
i am having an issue with my laser cutting machine bystronic 3015
im cutting inox 4mm and while cutting the material,
the power of laser decreases till the next part it can't be cutted,
i have lowered the speed to obtain an acceptable cutting but this doesn't resolve the problem
can anyone help?
sorry for the late response. most likely you have too much heat and not enough speed in the corners. crank up the modulation and play w the dwell
Chris Krug Maximum Up-time, Minimum BS
