Cut Extrude
PlasticFantastic
72
Is it possible to cut extrude through individual features rather than through the entire solid body in a part file.
As far as I know...the only was is to create a plane where you want to start your sketch, then cut-extrude up to a surface or plane where you want it to end.
hi
if the features are modelled as seperate solid bodies then
Try setting featurescope to the cut extrude feature.
u can select individual bodies through which the cut extrude has to pass
best of luck
CNKK [snail]
"HOPE : Sees the Invisible, Feels the Intangible and Achieves the Impossible"
I am assuming you are using all the appropriate sketch locations and end conditions (up to surface, two directions, etc., etc.)? I know it sounds like a dumb question but we get simpler and "apparently" obvious stuff asked sometimes.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
