VINN
- Feb 13, 2003
- 13
I have a cube(solid) which intersects a "s" shaped surface.This surface contains several surfaces. I would like to cut the solid to entire surface. I am guessing to join cutting surfaces, then use the cut comand?. But I have no expierence using cut in this fashion. Is this the proper way to go about it?, and if so how do I properly use the cut or trim command. Thank you ion advanced!.
BOTTOMS UP!
VINNY (-:
BOTTOMS UP!
VINNY (-:
