Hello all,
I'm new on this forum, and quite new also in the valve world.
Since last july, I (try to) handle a Fluid Finite Elements Analysis software to do flow calculations through the valves I design. In particular I'd like to use it to determine CV.
But the more I try to understand, the less I do...
I found a lot of tables with CV Max values for different sizes and classes, but I'm sooooooooooooooooo far to obtain them by simulation.
To give an example, I get approximately a CV of 200 for a 2 inches ball valve, but I should have about 500.
And I have numerous cases like this.
The models I use for simulations are based on the standards ISA S75-01 and -02, so I add pipes at the inlet and outlet of my CAD model.
Then I tried with a variety of limit conditions (pressure at inlet and/or outlet, flow at inlet and/or outlet,...) but nothing seems coherent.
Maybe someone tried something similar and should help me?
I can't ask anything in particular, because I ask myself so much questions about this.
Thanks a lot in advance for the good knight(s) who maybe will help me.
I begin to lose hope...
