Tony Hines
Petroleum
- Dec 19, 2018
- 1
If a standard carbon steel vessel with 150 series flanges is operated at max pressure of 75 psi down to a vacuum in a cyclic non-corrosive gas environment of 350,000 cycles per year, at atmospheric temperatures ranging from 0F to 110F, must the vessel have an ASME VIII Div 2 stamp or can it have a Div 1 stamp? Is it possible to have a Div 1 stamp that because of the low operating pressure range that unlimited cycles is possible?
