Cylinder Sheet Metal Flange Bend
Mechwill
51
Hi, All
Is there a way to create a flange on the tab from a cylindrical sheet metal? I could have created a part for extrution but it won't let me flat the part for the strip machine to bunch it out.
You have to flatten the part before you add the tab. Then you have an extremely good chance that Solidworks will not let you roll the cylinder up again because now you have a double curved shape.
B.E.
Create the part using the sheet metal Swept Flange tool, and then cut-extrude to create the tabs.
@berkshire I have tried your method and i am not too lucky afterall.
@CorBlimeyLimey I have tried that as well but i don't think i can create a flat pattern on this sheet.
A flat pattern can be created of the basic part, but will not include the notches.
The notches will have to be created in a separate config of the flat pattern.
That's currently a very sad limitation of SW.
