dthom0425
- Dec 6, 2018
- 47
Hi all - I'm curious as to how some of you might detail the press fit of a dagger pin into a metal plate.
I want to ensure that the flange of the dagger pin fully seats against the flat of the metal plate it's being pressed into. I've seen people put a .000 +.xxx/-.000 dim/tol on the drawing. I've also seen some fancy notes like "press fit dagger pin into part. pin flange shall not stand proud more than .XXX"
Curious as to how some of you may have handled this.
