qualitypro
We had numerous damages occur to the tubes in the tube bundle assembly in a new heat exchanger fabricated at our suppliers shop during assembly of the shell miters. The supplier told us that he will replace the damaged tubes based on a visual inspection and reuse the acceptable tubes that can be salvaged. Is there any inspection method/criteria that is required by Code that the supplier should follow to ensure that the tubes are good for reuse?
