Damaged tubes in tube bundle of Heat exchanger per ASME VIII Div.1
qualitypro
91
We had numerous damages occur to the tubes in the tube bundle assembly in a new heat exchanger fabricated at our suppliers shop during assembly of the shell miters. The supplier told us that he will replace the damaged tubes based on a visual inspection and reuse the acceptable tubes that can be salvaged. Is there any inspection method/criteria that is required by Code that the supplier should follow to ensure that the tubes are good for reuse?
qualitypro, I am not aware of any particular requirements, this would more likely be a matter of agreement among the parties. As well, the method of inspection may depend on the nature of the damage.
Mike
I would recommend a review of ASME SA 1016 General Requirements for Ferritic Alloy Steel, Austenitic Alloy Steel, and Stainless Steel Tubes material specification.
