Data driven calibration model (python)
Amine A
80
Hello community,
I want to formulate a data-driven calibration model between physics and simulation results. I have an a model encapsulated in an executable program (data_generator.py) that for a load 𝑃 located at 𝑦 = 𝐿, generate 𝑁𝐵 random beam widths 𝑏(𝑥) and computed the beam displacement 𝑤(𝑥) at 𝑁 positions, at locations 𝑥(𝑖) = (𝑖 − 1) ⋅ 𝐿/(𝑁 − 1) ( file attached shows the beam )
I run the two cases (simulation results 'case 1' and physical model 'case 0')
Usage: data_generator.py <case> ...
* Case 0: Physical model
Usage: data_generator.py 0 <L> <h> <b> <P> <N> <y>
- L: Beam length (default 1)
- h: Beam height (default 0.01)
- b: Beam width (default 0.01)
- P: Load (default 30)
- N: Number of steps (default 100)
- y: Position to apply load on beam (default equal to L)
* Case 1: Simulation results
Usage: data_generator.py 1 <L> <h> <b> <P> <N> <y>
it gives me results in file attached. I don't know how to proceed to do a data-driven calibration model. anyone has an idea please ?
IRstuff okat thanks I will see :))
GregLocock that's in the second case that the beam width varies with x
if I will do a polynomial regression should I fit the polynomial equation with physics model or simulation results ?
I know and that's why I will take it as the reference. I don't know how to fit simulation results to physical model, I don't have any equation for simulation results that's what makes me confused. If I will do a regression, I will consider a polynome that I will fit by determining its coefficients. But if you look at the first question he asked to do a data driven calibration model between physics and simulation results.
what is the problem if I just put (w1(x)+w2(x))/2 as a calibrated model please?? it give results between both models and give the minimal RMSE between both
It seems to me the whole point of parameterizing the equations is that the problem was given to you to fit a "black-box" physics phenomenological data to SOMETHING that can fit the data and predict the output of the black-box.
In fact, the data from the black box might not look anything like Roark's or Bernoulli's equations; we can only assume that the form is SOMEWHAT akin to the known equations for beam deflection
TTFN (ta ta for now)
Exactly , the output is clearly "w(x)" but I don't if the inputs here should include physical parameters like (P,h,L,...) or just coefficiens (a,b,c..) related to a polynomial function
