itsmoked
- Feb 18, 2005
- 19,114
I have to do capacity tests on a bunch of large batteries (not cells) so I can match them up. This entails reading the battery voltage and current (DC Hall effect coil) periodically and logging them. I'd probably then drag the log into Excel or similar to integrate for the capacity.
I have a really nice Stride instrument that is 8 isolated channels that can only be read via Modbus TCP. I've wasted hours trying to find a simple piece of software that will periodically read a couple of the Stride's registers and log them.
QModMaster seems perfect.. except it's brain-dead. It connects and polls the Stride correctly, the Stride responds with the correct data, then QModMaster decides Error: Address Incorrect freaking out and requiring human intervention to continue.
Advanced TCP/IP Data Logger Is absurd with no obvious way to set the specific register addresses but then the entire product line is like a morass of paid modules working to nickle and dime the victim to their knees.
modbus-tcp-data-logger looks cool and is cheap but completely refuses to even connect. (Likely a PC compatibility nightmare) :/
At this point I'd even go with a portable multi channel logger that (probably comes with) graphing SW side stepping the entire Modbus hassle and doesn't need an external power supply like this Stride does.
My budget is around $200.
SW or Logger suggestions?
Keith Cress
kcress -
Keith Cress
kcress -
