To all,
I am currently performing a corrosion resistant weld overlay to (6) 10' sections of shell that will later be welded together to make a 60' vessel as well as two hemispherical heads. I received the sections in 10' inc. rolled and seam welded. I considered the sections to be parts and was looking for Partial data reports and stamping on each section however that was not the case. I was told that the material would return to the supplier after my overlay, welded into a vessel and then the supplier would issue a U1 stamp and data reports for the job.
So my question is do I, stamp each section with my U stamp and return them with a U2 partial data report and just list "weld overlay"?
Thank You, Jim
Thank You, Jim
