Hi!
These questions are mainly related with precast concrete industry.
1. I wonder why DBAs are used instead of mild rebars,especially for connection hardware design.
2. Does ASTM cover coil rods? Why not, if there is no ASTM spec?
Thanks for your help!
If a welding gun is not used or minor help with Fy, I think there is no advantage to use DBAs.2. Does ASTM cover coil rods? Why not, if there is no ASTM spec?
Why are coil rods/bolts used instead of threaded rods or anchor rods?Are coil rods good for permanent structure or connections?
