Do you think it is right to design it as a 150cmx150cm column and rod element?
M
member 1218881
Guest
Hello, I am designing a building with etabs. 150X150cm columns available. It has a floor height of 4 meters. Do you think I might be making a mistake by modeling these columns as rod elements?
I think that you might be making a mistake in considering the use of these columns in real life. Too small for ties, fire rating...
Really hope they're steel columns and not concrete....
Why yes, I do in fact have no idea what I'm talking about
The rods element has me confused, might be worth a google video on etabs and modelling.
I am not an etabs guy but in my programs we would design the columns as frame/beam members
Ingenuity said:
1500 mm square columns for 4m height seems ok for me as concrete!
Friends, the columns consist of concrete filling inside a 70mm steel profile. So it's not just concrete columns. Concrete filled composite columns. The building is a tall building over 200 meters. (It won't actually be done.)
I'd just model it in ETABs as a column frame, you can even define it as a composite section directly. 1500x1500mm concrete column doesn't seem too outlandish for a 200 story building
Never used Etabs but I would assume a ROD element is a tension element!
