DBTT-Ductile Brittle transition temperature 2 1/4 Cr-1 Mo -P22/F22 Chrome moly material
deepu78
51
Have a query.
What is the DBTT-Ductile Brittle transition temperature for 2 1/4 Cr-1 Mo -P22/F22 chrome moly material?
Is there a formula for calculating this DBTT?
Is this DBTT valve fixed for all 2 1/4 Cr-1 Mo -P22/F22 chrome moly material?
Is there a chart available in ASTM / other standards?
DV
typing that into Google gives a temperature. and some discussion, and reference papers.
purchase the applicable standards and review them.
I googled before posting here, but couldn't get.
Standard Which one? I checked ASME SA-335 but not available there.
The DBTT for 2 1/4 Cr - 1Mo is all over the map depending on chemistry (control of C and residual elements), fine grain or coarse grain melting practice and heat treatment. It can range from around room temp to -40C.
