DC/AC INVERTER
LoicSCE
Automotive
Jan 9, 2003
3
I'm looking for an DC/AC Inverter with the following specifications:
Input: 200 to 460V DC
Output: 208/240V 3 phases, 6-8kW
This inverter powers an AC motor that drives the power steering, AC and air brake on hybrid-electric utility truck.
Any help will be greatly appreciated,
Thank you,
Loic Gaillac
Southern California Edison
Electric Vehicle Technical Center
loic.gaillac@sce.com
The main issue concerns the DC requirement, DC voltage is supplied by a NiMH battery pack. The voltage will range from 220V (under hard acceleration in full electric mode) to 460V (when the 60kW Capstone Micro-turbine is on).
The inverter should be operational within the all range of voltage (220-460V).
Loic
