Rooftop PV system approximate size 2MW. Weather station had a lot of signal errors which were blamed on the DC cabling causing interference. Grounding was correct. Cable was installed in PVC, unshielded, and run with 120V power cable approximate distance 150 feet. Problem was solved by installing filters at the weather stations.
Any IEEE papers on distance to DC circuits causing interference? Would like to rule this out as a cause.
