Tmoose
- Apr 12, 2003
- 5,633
I tried a few searches but came up empty.
There is a discussion about the correct sized cable to power a low end 12 volt DC winch to pull stuff onto a trailer. One participant has proposed that if an undersized cable is used the cable will heat up. But he then says " But if the wire starts to heat up, current draw can go up sharply, causing more heat, current goes up more yet, etc, etc and things start melting or the motor burns up. "
I don't follow how greater resistance will cause the motor to draw more amps.
With slightly reduced available voltage, and resulting slightly^2 loss in power, I believe the winch will have to run considerably longer, contributing to overheating of the motor and the cable, but I'd expect the current draw to be reduced.
Is my simplified view in error?
thanks
Dan T
thanks
Dan T
