Hi guys,
I need some help with my understanding of permanent magnet DC motor operation. I am building a spreadsheet to model motor performance. I'm an ME and my electrical knowledge is poor so I have started with the theoretical side to help develop my understanding. I have a few good books on the way, but would like to start getting feedback here as well so any help you can provide would be greatly appreciated.
The motor I am attempting to model is the AGNI 95R which can be reviewed here:
My spreadsheet is attached.
My first question is with current draw. Based on the information I have been supplied, both measured and derived from manufacturer performance figures, this motor has an armature resistance of 0.0125 ohms. This seems very low to me. Therefore, at 60v terminal voltage and low shaft speeds, hence low counter emf voltages, I see very high current draws. Theoretically speaking, is this correct or am I overlooking something?
If I was correct above, my second question is what occurs when you can't supply the required current? Assume I will only be able to provide this motor with 240 amps continuous. During an unloaded acceleration run, will it draw the full 240 amps from 0 rpm to the rpm point where the terminal voltage and counter emf voltage combine to require less current than 240 amps?
I'm sure I will have more questions, so thanks in advance for your time and help.
Chris Skarzenski
Chris Skarzenski
