lg1990
- Dec 17, 2021
- 2
I am comparing shearwall results with ETABS and S-CONCRETE, and I came across this difference between how the flexural/axial D/C ratio check is calculated.
In S-CONCRETE, a horizontal line is projected to the P-M curve. The DCR is calculated by the ratio of horizontal length (shown below)
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1639774034/tips/SCONCRETE_DCR_ovecu1.pdf[/url]
In ETABS, a projected vector is used to calculate the DCR. This in some cases would be conservative (with high axial loads), and unconservative (with low axial loads) compared to S-CONCRETE's DCR check.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1639774140/tips/ETABS_DCR_js3egv.pdf[/url]
Is there a code reference that directs that a horizontal line should be used for the DCR check? What have you typically done? Both programs will determine if the wall fails (outside of the P-M curve), but a inaccurate D/C ratio can lead to issues.
Leo
Leo
