De-activating auto connection of lines? 1
bdn2004
799
I'm using Visio 2007... I'm putting lines around certain items to form a rectangle, polygon, whatever. Even though I use individual lines Visio always auto connects the lines and makes it into a contiguous shape. Helpful sometimes, annoying most of the time. I usually need to bump one of the lines out slightly to fit more stuff in and you can't do it.
Is there a way to defeat this feature? I've tried some of the options in the various menus, nothing seems to work. Or is there a different way to draw that won't act this way?
This would be similar to EXPLODING a polyline in AutoCad.
You might want to play with the "Snap and Glue" settings.
From the menu Tools->Snap and Glue
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Thanks Cajun,
But that didn't work, I turned the Snap and the Glue off...still does it.
Is there no way to "EXPLODE" in Visio?
Don't think so. It treats the shape as a unitary shape, as opposed to a grouped shape.
TTFN
FAQ731-376
If the line segment is not selected Visio won't join it with the next segment. So you can draw one segment, click anywhere on blank space to de-select that segment, then draw the next, and so on.
Peter
