DeaftSight Commands
sawmillgirl
4
Hi, new to the forum and DraftSight but proficient in cad.
I downloaded DraftSight for my youngest daughter and can't find a Quick Dimension Command. Is there one in DraftSight like Autocad ?
She has Version V1R 1.4
Windows 7 IE 9 64 bit
Thanks in advance
sawmillgirl
Look under Tools>Inquiry
or command is '_GETDISTANCE
OSX 10.8.2 | DS V1R2.1
"DI" is the alias for DISTANCE command.
But what do you mean by QUICK DIMENSION? I've been away from AutoCAD for a couple of years, using SW and DraftSight. Is QUICK DIMENSION the one where you just pick on a line instead of having to pick the endpoints?
I use the ALIGNED DIMENSION button on the Dimension Toolbar a lot, if I don't use the LINEAR DIMENSION (Orthogonal) button.
