UCengno1
- Sep 22, 2005
- 70
A product we produce in specific configurations utilizes a splash lube planetary gearbox for speed reduction. The sun (nitralloy) and fixed ring gear (8620) are nitrided and the planets (9310) are carburized. In order to facilitate identification of lube refill we have recently added sightglasses which has led us to another discovery, significant dark colored debris in the gearbox. The debris is so dark and pervasive that it completely eliminated the usefulness of the sightglass.
We do not have wear related issues but this discoloration is very disconcerting to the customer and we have a competitive product that does not have this issue.
An analysis is in process but I am assuming the debris is worn carburize. I am also assuming that this has been an issue long before addition of the sightglass so I need to be careful to avoid solving one problem while creating another.
Am I correct in the assessment of the debris as a result of worn carburized layer?
Is there another wear issue that could generate the dark debris?
Would a completely nitrided set eliminate dimish the dark debris?
Trying to start down the right road from the begininning of an investigation. Thanks.
BCK
BCK
