DEBUG/EPRINT in ADAMS CAR
ichbinpulkit
Automotive
Aug 25, 2023
20
Hello @GregLocock,
You once suggested me to go through the DEBUG/EPRINT. I did, Somehow I am unable to understand how to determine the problem. Should I understand something from the Jakobian Matrix or search the part through it's ADAMS ID and look for what could be wrong.
In this case there is a lot of iterations and also steps then... How can I determine the root of the problem. You can maybe check the .msg file I have attached.
Viele Grüße
Pulkit Sharma
 https://files.engineering.com/getfile.aspx?folder=e4d8d960-fae9-4fc3-9116-ab645f545f77&file=test_accel.msg
The maneuver is finished. Therefore you can interrogate the model by looking at the gra file and plotting stuff.
Cheers
Greg Locock
Could you elaborate it somewhat better and deeper?
Why is it not there in the ACAR Help/Guidelines?
Viele Grüße
Pulkit Sharma
Thee lines here tell you that the maneuver is over
command: !
command: stop
Termination status=0
Elapsed time (sec) during dynamic simulation spent in:
Predict Correct Jacobian Eval Solver(NF) Solver(FBS) User Subs Contact
________ ________ _____________ __________ ___________ _________ ________
1.90E-02 1.82E+02 2.33e+01 7.27e+00 2.71E+00 8.79E+00 0.00E+00
0% 99% 12% 3% 1% 4% 0%
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 186.31s, CPU time = 41.95s, Average CPU load = 22.52%
Cheers
Greg Locock
