debugWIRE Device Programming
Erro11
28
One of the listed features of the ATMEL ATMEGA48A-PU microcontroller is that its nonvolatile memory can be programmed via its debugWIRE interface assuming that the DWEN fuse must be programmed via the SPI or Parallel interface before the debugWIRE interface can be used. Most of the programmers/debuggers indicate that debugWIRE can only be used for debugging and not for programming.
1) What programmer can then be used to program the nonvolatile memory through the debugWIRE interface with the least unexpected problems?
2) What is the best programming software and version to perform debugWIRE programming with the least adverse issues? AvrStudio4.18? AvrStudio 6.1? CodeVisionAvr3.06-ChipProgrammer?
What does ATMEL say?
Dan - Owner
Nothing yet. Their Sails rep nothing trustworthy that consideres real issues yet.
