decals!
uni1
20
hey guys, im working with rhino 4, actually im trying to build a model based on a raster image reference. i need it set on a surface which is gonna be adjusted around during work, so i thought about decals. i never did it, then i checked Vray help, i found the steps and i followed what was explained.
the decal doesnt display.
damn.
do someone have a tip?
thx
uni1,
You can paste an image into a sketch. Much simpler than putting a decal on the surface. Check the help.
-b
I assumed the image was coming from rhino. As for working IN rhino... I dunno. Since you're asking in a SWX forum, I assume you have access to SWX. You could do your trace in SWX and then export the curves to rhino as iges.
-b
