dgengineering
Hi everyone,
My client is adding a deck to an existing 2 story house ( See the sketch attached). The city requires that we check existing house for additional load per IEBC section 1103.2. My plan is to do a seismic analysis of the existing building alone and then with the deck. After that we compare these two cases to see if changes are needed to the existing house. . Also, I consider the exterior existing shear wall (adjacent to the deck, transverse) as my structural element to be checked. But before I do these calculations I have a few questions.
1. What R value to use for the deck? Is it R=1.5 if we treat the deck as timber frame cantilever system? I couldn't find any info about deck R values
2. Should I add the deck force to the existing house story shear at each level? Then compare the existing and proposed conditions, right? because with different R values I have to consider them as separate
structures attached to each other. That's what I think but correct me if I'm wrong
3. Let's say the demand/capacity ratio exceeds the 10 % Should I reinforce the exterior shear wall? I know it's my decision as a designer but If you have other solutions please share
Thank you in advance for your help )
