I am trying to simulate a Deethaniser to give 95 mol % ethane in the OVHD and minimum Propane. It is not converging with recovery spec or vapor fraction spec in the OVHD. Can anyone give any idea how to converge the column and which specs to be used. The Feed stream contains 9.5% Ethane, 0.5% Methane, 13.5% Propane, 18% Butane, and the rest higher HCs i.e. Pentane etc.
