Default settings, how to get them back
Ralph2
Industrial
May 3, 2002
345
Hello
A default intallation has 2 toolbars, typically docked on the side of a drawing. I believe they are called "draw" and "modify". Some "kind" (it's a family forum) person has remove all the buttons from the modify tool bar.
In AutoCad LT 2002.. HOW can I get them back?
Also... In AutoCad LT 2002 can I set up a personal profile? I thought I could but can not find where to start?
Thanks for any advice
Ralph
You can use the MENU command and change the "file of type" to MNU and find ACADLT.MNU (may differ as I am not an LT user)...
Note you will lose any customization.
- Tracy
Thanks Tracy
Trouble is there are others using this machine. Loosing all the customization might upset some. I am working around the problem by filling in the "empty" modify menu with icons "I" want.
Ralph
Under tools--->options set up a profile for yourself with the menu bars the way you want. Then you and the other users can switch back and forth between toolbar layouts as often as you like.
Thatr would be the best way.... unfortunately that seems to be one of the features that is missing from the LT (2002LT) version.
