RDelaCourt513
- Apr 23, 2019
- 23
Hi all, just looking for some help and advice on a NACA duct that i modelling up on CAD.
I am in the process of building a closed-wheel time-attack race car, I had a NACA duct intake that feeds air directly into the radiators and oil coolers. Unfortunately the carbon fibre moulded NACA duct I had before has been damaged on track and has destroyed the part.
I know I could just go out and buy the same spec duct but I want to practice creating carbon fibre components and this is the perfect opportunity before I progress onto larger (and more expensive)components.
I have populated the respected intersections derived primarily from the total width, depth and length of the duct profile.
I have attached some images of the 3D scanned geometry of the current damaged duct. as well as the excel spreadsheet populating the respected dimensions.
I realise that i'm probably going to do a terrible job trying to explain this, but basically im having difficulty defining the depth profile of the duct. as you can see in the attached excel spreadsheet, I have populated a profile. The starting point of the depth sweep is tangent to the flat A-surface (top) however on my 3d scanned model (and others i have seen online) the depth profile appears to run off in a different fashion as to the depth profile I have generated towards the end point. I need to ensure that the sweep is as per the data provided as i want to ensure that I have sufficient volume in the void.
How should I taper off the end of the duct that assumes the 75mm od profile.
Again apologies for the crude explanation, I really would appreciate any help
Thank you
Ryan
Thank you
Ryan
