mrmalcolm
Marine/Ocean
- Jan 24, 2024
- 53
In ISO4990-2023,the test blocks may be cast separately, attached to the castings or cast integrally on the castings.
In ASTM A781, test coupons may be cast integrally with the castings, or as separate blocks.
How to understand the test blocks casting integrally on the castings? Does Cast integrally on the castings means specimens cut and machined from the production casting itself?If not, how do you define the test blocks casting integrally on the castings?
Your early reply will be highly appreciated.
Best Regards,
malcolm
Best Regards,
malcolm
