Definitions of High Temperature and Fire Safe
RichDavis
5
I am working on a specification covering exchanger gaskets. I would like to specify the construction of these gaskets so as to identify them as being acceptable for use at High Temperature and or for Fire Safe Service. I would prefer to use definitions of these terms from an ISO, API or other relevant standards group.
To date, the only high temperature reference I've found is API-600, (Valve Standard) and API-607 Fire Test for Soft Seated Quarter-Turn Valves. I would rather find a heat exchanger or equipment standard to use for my reference.
