Ingenuity
- May 17, 2001
- 2,374
I have a simple span beam (wind column actually), spanning 60', uniform load, and input the W18x55 section from AISC database within RISA-3D. Single load case, the most basic of simple beams.
So I investigate RISA further, to explain the 125% deflection differences. I copy the file and in the new file manually define my Izz section props within RISA (890 in4 that equals the AISC value) and I get 5.8" deflection. Correct answer.
I am a somewhat new RISA-user, so I assume I am doing something wrong when selecting the AISC database within my model - does any one have any ideas on what I may be doing wrong?
I can attach the two RISA files, if needed.
From RISA-3D: Max moment at 232 k.ft. Max deflection 7.3" at midspan.
Hand calc: Max moment at 232 k.ft. Max deflection 5.8" at midspan.
