Ayham Shahoud
- Apr 7, 2022
- 7
I have an infilled steel frame system with a total height of 21'. I need to check both horizontal & vertical deflections. I used the value of (L/600) for vertical optimization under (D+L) as mentioned on (Masonry Building Code1-3-02) page12 /pls see the attached image/. However, it didn't mention the lateral deflection, so I used IBC2012 as a guide. IBC2012 /page 366/recommends for the plaster or stucco finishes to use the value (L/360) to check against wind load /pls see image/. Actually, I am concerned about the difference between both values since the wall inertia is the same for both directions in the plan.
ANY RECOMMENDATIONS PLEASE
