Aet20
- Dec 27, 2021
- 7
Have question regarding deflection of PTB results under the alternate loaded pattern, by logical thinking the deflection shall be the highest when the cantilever span is loaded as compared with both spans loaded and when the middle span loaded. I have modeled a few beams and the results turned out to be similar to where the cantilever span deflection is the highest under the both span loaded case instead of when it is loaded alone. Please enlighten me if there is other factor to look at.
