angel89571
- May 22, 2012
- 4
Hi everybody
I am working with NX 8.0 and I need to make a deformable, it is just a tube that should follow a guide line, I think that I need something called GUIDE STRING in order to get the deformable part in the assembly but I'm not sure how to do it or if I need a special license. I can make that a solid changes some measures but what I need is to fix a line between two points and the tube changes its properties following the guide line.
I hope you can understand the question and you can help me.
Thank you!
