Deforming thread to lock the nut permanently
edward995
Industrial
MY
I have seen some method to distorting/deforming the thread to prevent it from loosening, like staking or center punch one or more of the nut faces. Is this way suitable for larger and higher strength nut?
I am trying to apply it on 1 1/2 inch nut (30HRC) , any idea what kind of machine should I use?
We don't know if the OP application has an anchor point for the lockwire idea to work.
Ted
" devices that were submerged in hot oil"
F1 con rods are not submerged in hot oil, but are likely sprayed with oil at 200°F or more for hours at a time, and subjected to 100s of gs acceleration that varies direction 1000s of time a minute.
Not a single wrap of safety wire or a single DIN 7967 or Pal nuts to be seen.
70 years ago in engines expected to run at least 100,000 mile at 4000 rpm or so we might have seen this -
I am confident that those sheet metal Pal nuts were, and are, incapable of talking an under-tightened nut off the ledge.
To FACS,
I was envisioning something like this -
The crankshaft appears to be largely intact.
It may be more likely that the engine block broke than fasteners "loosened" .
The late, great Smokey Yunick often said that this or that poor engine building practice or tuning mistake would result in running over one's own crank.
We didn't have room to have enough thread engagement for using high strength fasteners torqued to yield like they do in engines. And we were fully submerged in 400-500F oil. and we didn't have access for maintenance for years on end, until something broke.
I have seen many 2-bolt main bearing caps fail. If it happens at high RPM the crank often ejects out the bottom.
