I have recently deleted some files from the vault by using the PDMWorks client. In addition to the vault, I have a copy of the files saved elsewhere on the network. After deleting the files, I decided that this was a mistake, and checked the copies that I had made into the vault with the same names as the old files. Now when I try to access the files in PDMWorks, they are not visible in the tree. However, if I try to check the copies of the files into the vault again, PDMWorks recognizes that the files are actually in the vault. Any thoughts on this one? I can't seem to find the file that PDMWorks is using to rebuild my vault tree, the tree.pdmw file doesn't seem to help here either. Any help would be greatly appreciated.
