Deleted Part Family Members in Assembly
Brett2008
Industrial
Sep 11, 2008
10
0
0
When I open an assembly it tries to load some of the deleted or missing part family parts. How can I properly remove the reference to these parts?
Brett
If they're part of the assembly, then NX will attempt to load them.
Unless, you're referring to the following ... Under Load Options, do you have Generate Missing Part Family Members toggled on ?
Specialty Engineered Automation (SEA)
a UGS Foundation Partner
Yes I do, But I also tried it with the generate missing parts turned off and It still gave the list that it failed to load them.
Thank you,
It appears that the family parts do not like to moved around in the assembly manager from parent to parent. The delete suggestion and regenerate worked great. Again thank you.
Brett
