Not so fast, mxmaciek. Review your own comments which are shown in quotes.
mxmaciek posts "Same time, demineralized water pH would be around of 7"
then why mxmaciek do you post graphs that show that the pH will not be 7?:
mxmaciek posts "Carbon dioxide (if present) would cause corrosion as well (5uS is deionized water rather than demineralized one, so I'd expect some sodium which can mask the CO2 in pH reading)."
mxmaciek, deionized water and demineralized water are the same thing. In addition, carbon dioxide is never present in the effluent of deionized water and/or demineralized water production equipment.
mxmaciek posts "deionized water: water after one or two stages of RO, typically with conductivity around 5uS. Same is if the final stage is anion exchanger only, without mixed bed or EDI.
demineralized water: water after mixed bed ion exchanger or EDI, typically with direct conductivity below 1uS."
mxmaciek, deionized water and demineralized water are the same thing. For example, Lenntech's definition of demineralisation: Any process used to remove minerals from water, however, commonly the term is restricted to ion exchange processes.
No competent water treatment professional would consider RO effluent (without additional treatment) to be demineralized water. There are many ionic elements still present in the RO effluent since the RO process is typically guaranteed to remove only about 90% of the ionic elements whereas ion exchange systems remove about 100%. The effluent from a cation unit is also not considered to be demineralized water either, since you have removed just 50% of the ionic parameters in the cationic demineralizer unit.
mxmaciek states "after RO it will be close to neutral."
mxmaciek, a mid-career water treatment professional like yourself should know that RO effluent typically has a lower pH than neutral because carbon dioxide passes through the membrane and will depress the pH until the carbon dioxide is removed.
