Depths Of Flow In Pipe
RjMelbourne
AU
Ladies & Gents
Please excuse lack of knowledge but I am still learning.
If I know a flow in a pipe, plus all the pipe characteristics eg. Grade diameter "n" value how do I establish the depth of flow the get my wetted perimeter.
Where this is leading is I have to prove that I have slime stripping flow and velocity in a sewer pipe. Problem is I know the pipe is not flowing full and I am unclear on how to establish the depth of flow to calculate the wetted perimeter to proceed with my mannings calculation.
Any help would be appreciated.
Calc the HGL through the system. Assume a reasonable tailwater on the last pipe, work up with loses through the structures. The HGL approximates the depth of flow.
But if you are just looking for v/vfull relationships, use Q/Qfull to get d/D. Go to pages 111-113 in this Manual:
Engineering is the practice of the art of science - Steve
Ok, Sounds like you need to establish normal depth in a circular cross section. This can be done the way lha adresses with v/vfull and nomographs or using math and the properties of circles. Rather than crunch out the equations now, I will look for the appropiate equations and post them later.
Sorry RjMelbourne for taking so long to get back but here are the eqs i mentioned:
z=D/2-y
A=cos^-1 (Z/r)
P=DA
R=A/P
"Angle in Radians"
Y= depth from invert
A=angle from vert to radius matching water surface
Z=center of pipe to water surface (r-y)
Hope this helps I tried to bring in a sketch but could not.
