Our Crude stream (main charge) will split into two parallel streams A & B. Each stream has it own preheat and desalter system.
Each Desalter has a PSV which will be discharged to the Crude tower. The PSV setting pressure is 13.45 BarG.
Since we are running at higher Crude throughout 40% over design, I was asked to check the PSV hydraulic system. The only scenario which will cause the PSV to popup is in case if we lost the booster pumps located downstream of the Desalter. Loosing these pumps will create high pressure in the desalter . The current operation pressure in both deslater is 11.0 Bar-g and operating temp. is 150 °C.
My question is, how can I calculate the PSV relieving loads if we assume Block outlet case?
What I’m intending to do is to use PROII to do a flash calculation at the operating temperature and at a pressure which is 10% above the setting pressure. (as per API 520). (adiabatic flash at 150 °C and 14.80 bar-g)
And then I will use the above results to use VisFalre program to check for PSV hydraulics.
Please confirm if the above assumption is right. Thanks for your help.
