John188
- Jul 8, 2016
- 25
I want to design a steel section to lift a structure. The section is supported at 8 different points to uplift the structure. Can anyone guide me to design the section? Thanks
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
r13 said:It is one time use. It is a stack liner with weight of 100T
robyengIT said:It is a stack liner with weight of 100T. So, need eight points to support it to prevent stress concerntration.
goutam_freelance said:It is a stack liner with weight of 100T. i need to uplift this structure and design a section for it
r13 said:Yes, metric unit. The liner is 120m high with diameter of 3.844m at top. The purpose of lifting is for installation
goutam_freelance said:If it is a stack liner will it be inserted inside an already constructed chimney shell? Then you need about 250 m lift crane. A really tall order !
