Design and construction of 126m tall flagpole Design parameters 9
Raja6
24
Hello Gentlemen,
Recently I have been entrusted with the assignment of reviewing design and construction documents for a 400 ft tall flagpole.
I am looking for answers to the following questions:
1. (ANSI/NAAMM FP 1001 07 Guide specifications for design of flagpoles) Which is the latest version of this specification? 2007 or 2013?
2. The maximum height specified in this spec is 300 feet only. Which spec is applicable for heights beyond 300 feet?
3. ASCE7 is referred in this specification. Do we need to use the latest version of ASCE7 2016 or 2022? Which ASCE7 is compatible with this spec?
4. What is the reference for coating for the steel?
5. What should be the minimum design life?
6. What is the allowable deflection? H/50 or H/60 or less?
7. Is any other reference code or Guide specification available in the industry?
8. What is the Risk category applicable? I or II or III or IV? Is this structure considered as a monument or special structure?
Thanks for your input in advance.
I've got no good answers to your questions - but does the design you're reviewing include tuned mass dampers?
The AASHTO LRFD Specifications for Structural Supports for Highway Signs, Luminaires and Traffic Signals would have some basic design parameters; enough to give you the fatigue stress limits for different connection details.
The design approach used for large electrical transmission towers might get you closer to what you're designing.
The loading, however, is another matter. For something of that scale and complexity, there are anumber of aeroelastic phenomena that can only be quantified by scale model testing and analysis. We found that out the hard way. We followed the standard design approach for our 120' high mast light towers (HMLTs) and we've had a number of them develop fatigue cracks and a few snap and fall over. Luckily none of them fell on anyone or anything. There was a galloping effect that was unanticipated and created cyclic loading effects well beyond what we designed for.
You'll probably need to do as we did for our HMLTs, and employ a consultant who can do the advanced computer modeling and wind tunnel testing, to capture the effects of wind, rain, ice, etc. The firm we contracted with was able to recreate the galloping effect we observed, and was able to test our new configuration, and when it exhibited the same issue, they provided options for dampers. Then they were able to test the damper options we thought were feasible to implement. It was a long and expensive process to get to what we hope will be a durable pole.
There are some car dealerships around here with relatively big flags. I've noticed a few of those can have visible deflection in the wind. So one question: Is visible deflection and/or vibration acceptable even if the design criteria are met otherwise? If not, one step is to determine what that maximum deflection or vibration is from a cosmetic standpoint.
That is quite the list of questions, have you reached out to the local jurisdiction for guidance on the code version? The AHJ is the only ones who will know what version of code they have locally adopted.
It appears you may be newer to engineering? Do you have a mentor? With a structure such as this, there would be significantly more checks than just wind loading and weight. Wind itself could create a galloping effect on the pole, there may be vibration concerns, even the base connection could be quite challenging to design.
You say "reviewing design and construction documents" are you acting as the engineer, or checking another's work?
A few of your questions would need the owners input as well, ie life span, their allowable deflection tolerance, etc.
I assume you would need electrical and lighting in a structure this tall as well, have you considered how this will be routed, will there be access plates, how do they affect the strength of the member, etc.
and lightning, too maybe...
That's a good reference, dik. I would presume that the recurrence interval would need to be higher than 50-years if there are any structures within 400 ft of this pole. Unlike a typical flagpole, this one could smash through just about anything it came down on, so it would be subject to a higher factor of safety.
Isn't there a customer / owner for this little thingy that should answer some of these questions?
azcats... no dampers are considered
Thanks so much Bridgesmith for your valuable input.
Aesur I am not new. I am reviewing on behalf of the owner the EPC contractor's design. I am doing the peer review.
Aesur Pile foundations with pile cap is proposed to anchor the carbon steel pole with anchor bolts.
la belle vie there is no airport nearby but it is closer to the sea
la belle vie it is vertical cantilever with out guys
dik I have this Guide with me... I want to know whether FP 1001 -07 is the latest or FP 1001 -13 is the latest because 13 is refereeed in both ASCE7 -16 as well as ASCE7-22
Little inch Thanks so much for your input. I am first timer to this forum. I already read this post which you had shared. Thanks for the link any way. Trident support is also a good link. Thanks again.
