Design aspects of a cement grinding unit
arunmrao
Materials
Oct 1, 2000
4,758
0
0
IN
I manufacture castings for wear applications. However I am not familiar with the design of internals of a ball mill. I shall be glad if some individual or institution can be of help. This I need as I am encountering some prpblems during spares manufacture.Thanks in advance
Dr Arun Rao
If you could state the problems you are facing it would be easier to let you know some information as required.The main actions taking place in a ball mill are cascading & cateracting actions by balls of differnnt sizes.Mill is lined from inside by liners of Mn steel casting & the grinding ball used in the mill are of Cr steel casting.High Cr casting in first chamber [say 17 to 20%]& lesser Cr in the second chamber[say12 to 15 %]. The mill shell is of BQ quality steel.Other important parts are trunion, its bearing etc. You may be having this information with you. I am sure you are not looking thie type of prelimanary information.Other information may be posted such as hardness requirement etc if required.But please specify your problems/requirement.
